TR 7 Rollover Bar
DJV
TR 7 Rollover Bar
Postby DJV » 09 Mar 2009 20:05
I am new to the TR scene but thankfully have now seen the light and got myself a TR7 V8 DHC ............What a machine !!!
I have managed to get myself a rollover bar but am struggling to find out how to fit it correctly. First attempts to 'dry fit' have resulted in the bar fouling firstly the seat belt mount then the other extreme of the bar fouling the last hoop of the roof HELP
appreciate some guidance on this noting I have tried to find detail from the forum archives but not had any success as yet
Postby PeterTR7V8 » 09 Mar 2009 20:32
Welcome new member. May the sun shine on your upholstery.
What roll bar have you got? This can be a request from hell for new members but can you post some photos to show us the problem & show off your new car?
Postby windy one » 09 Mar 2009 20:37
If the bar you have is like the one I currently have, which it sounds that way, the (retracting)seatbelt assemblies need to be altered/moved. Mine were moved forward with a small 'L' shaped bracket to allow bar to fit.
DJV
Postby DJV » 09 Mar 2009 20:38
I believe its called the Alley bar which has the clearance 'hump' on the top mount and the chassis plates have three holes in..........noting when I look at the chassis rails its to fit against there are no guide holes there ???
Postby john 215 » 09 Mar 2009 20:40
Hi John,
WELCOME TO THE BEST TR7 / 8 FORUM IN THE WORLD EVER [8D]
Had the same problems with mine [V] but thanks to Steve up at S+S Preperations got it sorted ( http://www.ss-preparations.co.uk/ ), mine was one of there originaly but i got second hand off Fleabay.
If yours is like mine-
The three hole on the side, the centre one lines up with a bolt already present, it you gently pull back the carpet on the side below where the hood frame bolts on you will see a 10mm headed bolt this locates the bar.
Now you may have to trim the bottom of the hoop where it touches the floor. place the frame on the rear shelf, mark and drill the holes through the shelf, now unless you remove the fuel tank [:0] [:(] you cant get to put a nut on the N/S inner bolt as tank is in the way!!
The outer bolts go through into the wheel arches so some paint and waxoil on the holes ect.
Mark and drill the remaining 2 bolts each on the sides, now Steve rec welding nuts into the body for these but i used 'rivnuts' ( a sort of pop rivet with a thread inside it). Bolted all up nice and tight.
IF the hood hoop hits, it probally will! then the hood can be adjusted upwards on its mounts (also tightens a saggy hood [;)] ) or slot the side mount holes in the roll over bar to allow for adjustment.
Hope this helps,
Put some pics of your new car if you get a chance
Cheers John.
DJV
Postby DJV » 09 Mar 2009 20:52
John, Thats the one I have got and your info is excellant and really appreciated, but could I just ask do the top mounts sit behind the seatbelt mechanisms ?? ta
Postby john 215 » 09 Mar 2009 21:53
Hi John
No problem mate, will take some pics tomorrow eve, a picture can replace a thousand words!!
Postby saabfast » 09 Mar 2009 22:07
That looks like the one I have and the top mounts sit on the shelf behind the seat belts. I didn't fit it (was on the car when I bought it), but there is no sign of the belt positions being altered.
Saab 9000 Stg 1
Saab 9000 2.3 FPT Auto
DJV
Postby DJV » 10 Mar 2009 18:22
To everyone who's responded so far..............I am very impressed and it's really encouraging that members are so willing and helpful to a request from a new boy !!
I am trying to sort out how to show pictures of my new toy and hopefully I can get them on soon
as I say a big thanks to you all
TR 7 V8 DHC
Postby john 215 » 10 Mar 2009 20:12
Hi John,
Pictures of behind the seat belt reel
And
Sorry about poor quality but bl88dy freezing out there tonight!!
Hope this helps,
zekow1
Postby zekow1 » 10 Mar 2009 21:27
Hi Guys
1) Does this style rollbar stop the back of the seat from going all the way back .??
2) Does is intrude with the side of the seats
3) And does it make it harder to put up and take down the top???
4)How thick is it?
haveFun be Safe
Postby saabfast » 10 Mar 2009 22:14
In my case, no, no and no.
The tube that goes down to the floor is to one side if the seat. The only things I find with the roof are that one of the plastic trims catches on it if I don't hold it tight to the roof, probably more to do with a warped trim, and it is almost impossible to use the zip out rear window (if you want to).
Not sure what you mean by 'how thick is it'? I do not have the car here to measure but the tubes are probably about 1 1/4" dia. The two tubes are vynyl trimmed as they come together and across the top, probably about 2 1/2" thick across the top and widening to about 5" some 6" above the shelf level at a guess.
Saab 9000 Stg 1
DJV
Postby DJV » 11 Mar 2009 17:55
John,
Your right, pictures save a lot of words, and these answer my question.
Really appreciated and no prizes for guesing what I'll be up to this weekend !!!!!!!!!!!!!!!!!!!!!!!
Thanks
TR 7 V8 DHC
Postby john 215 » 11 Mar 2009 18:49
Hi John,
No problem mate been a pleasure, I had to slot the holes in mine slightly to lower it so to give a good clearance for hood.
One other thing i noticed it stiffened the body shell as well [8D]
Any problems you where to find us!
Postby bmcecosse » 11 Mar 2009 23:10
My Aley bar does 'catch' the hood slightly - just have to lift the hood frame over it slightly as it goes up/down.
Image Image ImageImage
Users browsing this forum: No registered users and 55 guests
