IS THERE A BETTER LOOKING IDEA THAN JUST A NUT?
Postby Wayne S » 05 Feb 2009 21:15
Ken, quite simple I think. Cut to desired length and re-thread with correct pitch die.
I have to confess that this was Grinnalls doing not mine, but its been done on both my cars and stops them feeling like a lorry. On the V8 this is combined with a short shift housing (i think again basically it has a section cut out from the middle and then re-welded). Gives the gearbox a much closer throw and feel.
Last TR
Postby Last TR » 05 Feb 2009 22:32
The shortened stick sounds like the easiest place to start. Thanks.
Ken
Anchorage, Alaska
Postby silverseven » 06 Feb 2009 01:28
Or get yourself a ± 14mm alloy tube which you place over the gear stick and use the gear knob from a Mini ...
So if I properly understand Theo, you shortened the standard shifter, and slide the alloy tube over the stick then thread the new Mini knob on the old gear stick???
Postby Beans » 06 Feb 2009 09:42
Correct (b.t.w. it's an aftermarket gearknob from a (classic ) Mini)
Postby Odd » 06 Feb 2009 16:37
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Ken, quite simple I think. Cut to desired length and re-thread with correct pitch die.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Or you can do it the <u>correct</u> way: Lathe the welds away, lathe stick suitably shorter, Re-weld...
Postby PeterTR7V8 » 06 Feb 2009 19:07
My shifter has a short shifter extension under the stick which makes it sit a couple of inches higher. I almost have to reach up to shift but the throw is only about 2.5" from odd to even gears so it feels nice & racy. [8D]
Odd, how did you get to have your console knobs above the stereo?
Last TR
Postby Last TR » 06 Feb 2009 19:52
Odd,
Very nice! I especially like the shortened gearbox extension. Did you do all the work yourself?
Ken
Anchorage, Alaska
Postby Odd » 07 Feb 2009 05:37
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Odd, how did you get to have your console knobs above the stereo? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> By use of old sins/knowledge from a plastic-model building youth...[:I]
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Odd, very nice! I especially like the shortened gearbox extension. Did you do all the work yourself? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> I did it all, except the actual alloy welding. That I outsourced to a true alloy welding vizard...
Postby Shauniedawn » 07 Feb 2009 21:49
Hiya.
Nice bit of work there odd. Can you post the same pictures but bigger please?
Shaun
Postby jclay (RIP 2018) » 07 Feb 2009 22:21
<b>Shifter Housing:</b>
I am editing an article written by Odd about the shifter housing modification with bigger photos. It will be up on the Technical Site soon.
<b>Shortened Shift Lever:</b>
$25 US
[url="http://www.thewedgeshop.com/popupshortshifter.htm"]Link to description[/url]
Last TR
Postby Last TR » 07 Feb 2009 23:37
Very cool.
Ken
Anchorage, Alaska
Postby Shauniedawn » 07 Feb 2009 23:43
Hiya.
That's great - thanks Jclay.
Shaun
Postby silverseven » 08 Feb 2009 01:48
only 25$.....that's actually one heck of a deal[:p]
Would be very worth while to purchase one while making an order and combining freight!
