CONVERTIBLE T-STRIP QUESTION
Postby tr7inc » 14 Oct 2008 15:03
Hi all, just had my front bumper, off today to refurbish my bumper bar etc, not that there was only 2 nut and bolts holding the black plastic T strip on, there are 6 holes and thought maybe all i needed was 4 more nut and bolts but having looked on the Rimmers website, it says on there that plastic rivits are whats used ,does it makes any diff which are used? or is the black rivits cosmetically better to look at than silver boly heads.
Many thanks all
pupinabox
Postby pupinabox » 14 Oct 2008 16:32
Just took a look at mine. If you are talking about the two pieces over the bumper, mine are held on with bolts, but they go thru a black plastic washer that has a little flip cap on it that closes on top to hid the top of the bolt.Image
Postby tr7inc » 14 Oct 2008 16:46
Excellent and it looks neat too, many thanks, i'll get myself some of those.
Henk
Postby Henk » 14 Oct 2008 21:48
Well that plastic rivets are original mounted but you shall destroy them with removing a second time.
Henk
1980 TR7 US Convertible
1978 Mini Clubman Estate
Postby tr7inc » 15 Oct 2008 06:02
Hi Henk, yeah you are right, mine didnt even have any rivits, it was held on by 2 but and screws at the front, and at the sides the cruise lights held the sides on, ive boug ht a set of screw& nuts, along with some hinged cover caps that should equally do hte trick.
Postby gaz » 15 Oct 2008 12:25
anyone who does number plates will sell you those thats also what i put mine on with
Postby jclay (RIP 2018) » 15 Oct 2008 13:48
Drop heads in US had the plastic rivets. Use a punch to push out the center pins then remove the rivets. Find the pins on the ground and you can reuse the rivets.
Postby tr7inc » 15 Oct 2008 14:05
Many thanks guys, i think ive solved that problem, onwards and upwards until next litle prob i find, the more i delve the more i find!
Bill
Postby Bill » 16 Oct 2008 03:02
I bought a packet of the black plastic rivets at Auto Zone for $2.99 (8 per package) and they look great. You'll have to imagine it though, got no pic to post.
Bill
1980 Persian Aqua DHCImage
Postby tr7inc » 16 Oct 2008 06:48
Hi Bill i bought i pack of 48 of £1.99 in my local DIY store, good value i thought
Henk
Postby Henk » 16 Oct 2008 21:09
Now, that's a deal!!
Henk
