Been TR7 viewing today
Postby RUDDY » 25 Jul 2008 17:08
Whilst the wife and kids soaked up the sun in the garden I ventured ten minutes from home to view a car I have heard of a couple of times. It has been laid up for a while and is definately in need of work but has some things that appeal to me
1. It's a locally registered car
2. Low number of owners
3. Early fixed head
4. No sunroof
5. 5 speed box
It appears to have good doors, rear arches and front wings. Engine bay is a different story with multitude of plates and indifferent welding. Interior was reasonable and seemed/smelled dry. It is stored in this location for the owner, I left my number to pass on although I don't think its the car for me, then again I am a sucker for a resto so I'll probably end up with it [:D].
cheers, Paul
Postby Maxwell » 25 Jul 2008 17:31
Paul.... Go For It!
It's in the right colour for a Fixed-Head!
Maxwell[8D]
Postby paul w » 25 Jul 2008 17:38
Yeah,whites great,but remember to paint the sills black - how they
should be.An early car with no hole in the top,a rare thing these days.
Those wheels will have to go and that decal on the front is wrong
if its a Speke wedge.
Whats the vin/chassis no.?
Does it come with that theft deterrant...i mean gear box!
tr7 and rover sd1 girl
Postby tr7 and rover sd1 girl » 25 Jul 2008 17:42
thats a gorgeous car i wish i had that does it need much work??
Postby RUDDY » 25 Jul 2008 17:54
[quote]<i>Originally posted by tr7 and rover sd1 girl</i>
In a word - yes
If I ended up with it I would expect a full bare shell rebuild, the inners and strut tops are quite bad as is the panel below the screen. There are blisters under the paint on the rear deck and at the top of the front screen pillers. There has been a fluid leak down the bulkhead and lifted the paint, expect the sills have had work hence the white paint on them. Would probably end up with at least 5 times more in the car than its true value. I didn't catch the VIN but the plate was on the passenger seat, no room for it on strut top for crap welding. Sounds like a bargain [:D]
Postby TR Tony » 25 Jul 2008 19:32
Well it looks to have some good points, Paul, but pleased to see you have a critical eye. It does look mostly original & if you are approaching it as a restoration project then it could be a good basis.
Non sunroof is quite rare ( & personally I think they look great), & if the 5 speed box was factory fitted then that is also quite rare in the early cars when the 4 speed was more common. If it has been converted from a 4 speed to a 5 speed then try to find out if the diff was changed to the correct ratio as well.
Try to get a look underneath at the floors & the rear suspension mounting points.
And that VIN/chassis plate should be attached to the rear face of the passeenger door in those early cars. There would have been a body number plate in the engine bay, probably on the passenger side turret or thereabouts.
1980 3.5L V8 DHC Jaguar Regency Red</font id="size1">
Ianftr8
Postby Ianftr8 » 25 Jul 2008 20:19
That looks like a good starter, if you get the chance go for it!!!
Just think what could be achieved - could even be a rally replica[:)]
Ian
Ian Freeman
1979 TR8 DHC California car that never crossed the pond
1962 Triumph Courier
Postby bmcecosse » 25 Jul 2008 21:29
Was the 5 speed fitted to green-seat S reg cars ?? I would check the VIN etc carefully in case the car has had an identity transplant at some time ! Are there not still some NEW FHC bodyshells going around ?? New shell transplant would make a very long-lasting car if done properly.
Postby TR Tony » 25 Jul 2008 22:30
There are a few FHC unused shells apparently, but all late ones with sunroof apertures I believe. And probably in need of a lot of preparation after all these years in storage - maybe as much work as doing a good repair job?
Postby Chris Turner » 26 Jul 2008 12:29
There were 2 left earlier this year. A few have been used to make new rally car shells. At the asking price of £2,500 it would not be viable to restore an ordinary FHC with one.
www.triumphtr.co.uk
TR8 FHC
Postby RUDDY » 26 Jul 2008 13:22
Well I have put the wheels in motion to get my TR7 funds together
http://www.pistonheads.co.uk/sales/634016.htm
zekow1
Postby zekow1 » 26 Jul 2008 15:05
Ruddy
If you are going to do ,to the tr, what you did ,to the escort
Go for it . you have a great hand
Hey !!!you want to help me with my 2+2 project???????
Zeke[:D][:D][:D][:D]
gairo1
Postby gairo1 » 26 Jul 2008 15:54
The green interior looks good!
Postby bmcecosse » 26 Jul 2008 22:07
At £2,500 for a 'new' shell - I would say that's a fantastic deal. Could easily spend far far more than that 'rebuilding' a rotten car - and it will never be as good as a 'new' shell transplant.
Postby RUDDY » 27 Jul 2008 21:00
Took a deposit on the RS today, looks like its on its way to Southern Ireland .
