In line fuse
samco
In line fuse
Postby samco » 21 May 2008 00:29
Located by the fuse box there is an in line fuse with brown wires to it. Does anyone know where this fuse holder is supposed to live and what does it do
www.metronewquay.co.uk www.wheelintheheel.co.uk
Check out my album
1980 Californian import converted to right hand drive V8. Under construction.
Rayjones
Postby Rayjones » 21 May 2008 06:35
At a guess, could it be a fused live for the radio, perhaps a later addition!
Ray
1980 UK BRG 2L DHC
Henk
Postby Henk » 21 May 2008 15:47
It's the headlamp circuit breaker it's folded in or around the fusebox.
Henk
1980 TR7 US Convertible
1978 Mini Clubman Estate
samco
Postby samco » 22 May 2008 07:32
It has a brown and purple wire to it which goes to the relay for the hazard warning lights.
Check out my album
Postby TR Tony » 22 May 2008 09:22
Well Lucas wiring did follow a code & as far as I can find out a brown wire with a purple tracer would be a direct unswitched but fused live supply from the battery.
However if it is a purple wire with a brown trace then it would be horn fuse to horn relay when horn is fused separately.
Brown with purple sounds more likely as I guess the hazard lights would have a direct live feed so that they could be activated any time.
