Weather Stip Clips
Weather Stip Clips
Postby john 215 » 22 Mar 2008 16:07
Spent the day fitting a recon door to my DHC. Fitted the weather strip that goes on the outside of the door against the glass, normally getting the clips on is a total pain in the ar5sa [V] as you push one on another springs off or you dig a lump out of your finger [B)] or worse still your paint work [:(] BUT used the correct tool, apperently desined by Triumph themselves, and went on really easy [:D] Anyone going to change this strip, do yourself a huge favor and get one [;)]
And cheap as well [:D]
Postby gaz » 22 Mar 2008 17:22
where did you get yours from john ive ha a couple of half hearted attempts to put mine on and i always give and do something else
It rides again
Postby john 215 » 22 Mar 2008 19:12
Hi Gaz,
Got mine from Rimmers in there last sale offer sheet but i am sure all the 'regular' suppliers list them.
Rimmers Bros part no. is-
RX 1562
There is a knack to using it, you have to push the seal down as you pull the clip up with the tool but once you work that out it really is easy [:)]
Postby gaz » 22 Mar 2008 19:50
are you able to do it with the glass in
It rides again
Postby john 215 » 22 Mar 2008 20:38
Hi Gaz
Cant see why not, will try tomorrow got a 'old' clip left (got new one's at the same time as the seal) so will put that on and let you know.
Users browsing this forum: No registered users and 46 guests
