no key
syol
no key
Postby syol » 14 Jun 2016 14:37
Hello, I wonder if it is possible to make key for the trunk and glove box without the original key.
Thank you
TR8 V8 3,5L 1980
TR7 DHC 2.0L 16s
3 tr7 DHC 2.0 L 1980
TR7 FHC and sunroof 1981
http://www.tr7.fr
Re: no key
Postby FI Spyder » 14 Jun 2016 14:56
If you take the cylinder out (hopefully they are unlocked) and take them into a locksmith, they should be able to cut a key. As for blanks the locksmith in 'lil old Duncan had them on the wall (although that was a few years ago).
Re: no key
Postby stevie_a » 14 Jun 2016 16:02
I know my glove box didn't have a key, as has been said if open, then yes you can.
This is how I did it.
I removed the lock from the glove box very carefully, when you remove it the springs leavers can pop out, I put my boot lock key in as far as I could ( don't put pressure on it ) as you pull the lock out the further the boot lock key will go in.
Once removed make sure your boot lock key is fully home and then what I did was grind off the excess tabs that are sticking out with the bench grinder. Once all the tabs are the same shape as the lock fit back in to the glove box and fix it in, after that I could lock and open my glove box with my boot lock key. :shock:
syol
Re: no key
Postby syol » 14 Jun 2016 18:09
Thank you !
I thought that there were numbers on that barrilets premette redo key.
It seems that Christopher had to talk to me.
TR8 V8 3,5L 1980
TR7 DHC 2.0L 16s
http://www.tr7.fr
supercass
Re: no key
Postby supercass » 14 Jun 2016 18:44
A Heritage certificate will typically give you the original key numbers but of course the locks could have been changed at some stage!
supercass
syol
Re: no key
Postby syol » 14 Jun 2016 20:43
Thank you for the information, it's worth may be worth a try?
TR8 V8 3,5L 1980
TR7 DHC 2.0L 16s
http://www.tr7.fr
Re: no key
Postby rugbyref1 » 14 Jun 2016 20:47
I have almost all the original key numbers ... and someone who can cut from those numbers
Christopher
syol
Re: no key
Postby syol » 16 Jun 2016 12:59
Thank you all for your reply.
Christopher, you need to control what?
Thank you
TR8 V8 3,5L 1980
TR7 DHC 2.0L 16s
http://www.tr7.fr
Re: no key
Postby rugbyref1 » 16 Jun 2016 13:14
Syl, email me the VIN and i will check the database (drcsmith2@hotmail.com)
Christopher
syol
Re: no key
Postby syol » 16 Jun 2016 19:58
Christopher Ok, I buy tr7 of Josselin, who was in the south of France.
Engine broken. So I ais redeem him.
See you soon
TR8 V8 3,5L 1980
TR7 DHC 2.0L 16s
http://www.tr7.fr
swordfishdani1960
Re: no key
Postby swordfishdani1960 » 17 Jul 2016 10:58
Why would want to lock it ,cost you more for a new glove box , there easily broken
save your money, mate
Users browsing this forum: No registered users and 72 guests
