The heater doesn't' appear to be working on my tr7 v8. The levers appear ok - could it be airlocked or anything lime that ?
The car is running up to heat, so I'm sure it isn't the thermostat.
Ideas chaps ?
Brian
Brianc wrote:I think i will test the thermostat, then give the sustem a full flush, then fill it with the correct fluid - out of interest, being lazy, what spec is antofreeze
Brian
sheetsofsound wrote:I had the exact symptoms you describe. Turned out to be a blocked heater core and the wrong thermostat - both things previously mentioned. I didn't figure out the thermostat until I had taken the matrix out and rebuilt it. I replaced the stock heater core with one from a VW. (The VW one cost me about CAD60 instead of upwards of CAD150.) Once that was in the car, it became apparent that the thermostat was too low. Now I get lots of heat.
dursleyman wrote:sheetsofsound wrote:I had the exact symptoms you describe. Turned out to be a blocked heater core and the wrong thermostat - both things previously mentioned. I didn't figure out the thermostat until I had taken the matrix out and rebuilt it. I replaced the stock heater core with one from a VW. (The VW one cost me about CAD60 instead of upwards of CAD150.) Once that was in the car, it became apparent that the thermostat was too low. Now I get lots of heat.
Could you explain a it more about the heater matrix swap and how you did it. Do you know which model your replacement core came from etc etc. Any pictures?
I am sure a lot of folks on here would love to know when they need to replace theirs.
Users browsing this forum: No registered users and 109 guests
