Disco lights
alanjarvis
Disco lights
Postby alanjarvis » 05 Dec 2009 09:33
A fault has developed in the recent damp weather with my head lights. As soon as you switch them on to side lights the pods pop up and down none stop till you switch the lights off. They flash ok and I have disconnected and cleaned the red connectors behind the lights under the bonnet and cleaned the earth connection there. Where should i try next? Could the switch on the dashboard be playing up, note that the disco lights performace starts on side lights! Where is the control box?
Thanks
alanjarvis
Postby alanjarvis » 02 Jan 2010 10:41
Anyone got any ideas on this???
Postby saabfast » 02 Jan 2010 11:33
The initial advice is always to start with cleaning the connectors under the bonnet behind the lights, and then the take the switch apart and clean the contacts, then check the relays. If both lights are doing it the switch is the common point. It is quite easy to take apart, just note where all the contact strips go and how they fit.
If you need to get into the motors and limit switches I think there is more info on the lights and how they work on Jclays site, but it is unusual for both to go out of adjustment together.
Saab 9000 Stg 1
Saab 9000 2.3 FPT Auto
Postby TR Tony » 02 Jan 2010 16:11
I think the dash board switch is the likely culprit. Start with cleaning that up, or maybe you have a spare you can try?
TR8 FHC EFI Factory development car Inca Yellow</font id="size1">
Postby jclay (RIP 2018) » 03 Jan 2010 01:55
[url]http://www.team.net/TR8/tr8cca/wedgelab/other/headlights/headlights.htm
[/url]
alanjarvis
Postby alanjarvis » 16 Jan 2010 09:39
I bought a new dash switch from Robsport and fitted in this morning and the lights now work properly. Thanks for your help everyone.
Cheers!
Alan Jarvis
(Its not a fault, its a feature)
Postby John Clancy » 16 Jan 2010 09:44
Good news. Now make sure you keep everything around the headlamp pod mechanicals and electricals sprayed up with WD40 as that works miracles in keeping the troublesome lights working normally. Just the external electricals, not in the dash.
