I will start with your last questions first.
Remove the clutch slave cylinder from the engine/trans adapter plate. Have someone slowly move the clutch peddle and check for movement on the slave cylinder piston.
If you try to re-install the slave cylinder with the original bolts, you will strip the threads in the bell housing. So BEFORE you start, go to the auto parts and buy two new bolts, the same size and thread pitch but 1/2" longer. Install the slave cylinder with the new bolts. When both of the bolts bottom out, remove one and install one of the original bolts in its place and snug it up. Replace the remaining new bolt and replace it with an original and bolt the slave cylinder into place.
OK, now run the engine until it is heated up well before trying these steps.
1. Turn off engine, block wheels, set parking brake, shift into 2nd, depress clutch peddle and try to start the car.
2. Tow the car to an empty strech of road. Have the tow car move to the back of your car. Turn on the key, shift into 2dn, depress the clutch peddle and have the other car push your to start it. Drive around while holding the clutch peddle in and blipping the gas. When it breaks free, drive home.
