14" wheels
mattwrigg
14" wheels
Postby mattwrigg » 26 Mar 2008 20:37
Hi all
I have a Midget that has a TR7 rear axle. To make life easier I will be redrilling the front hubs to match the rear PCD.
I also need to use 14" wheels to clear my front brakes.
What options do I have in terms of 14" wheels? I don't particularly want minilites, nor am I keen on the 5 spokers (with black inserts).
Any suggestions?
Thanks
Matt
Postby paul w » 26 Mar 2008 21:02
Woolfies!Woolfies!Woolfies!............Woolfies!(you need all 4!)
(unless you got a Reliant Robin)
Postby TR Tony » 26 Mar 2008 21:59
Matt, if you discount minilites & similar styles, then you don't have a great choice left in 14" (apart from Wolfrace of course!). Revolution wheels come up on Fleabay sometimes as another alternative.
The TR7 PCD is not the most common but if you went to 15" wheels then you could use the alloys off the modern MGF, or those from the Montego or Maestro.
Alternative is to get the wheels you want as blanks & get them drilled to the right PCD (which is 95.25mm)
Postby bmcecosse » 26 Mar 2008 22:27
Yes - Wolfrace wheels !
Postby Wayne S » 26 Mar 2008 22:51
I like compomotives [:D]
Purple 2.0 Litre DHC Grinnal
mattwrigg
Postby mattwrigg » 27 Mar 2008 10:03
Anyone got any woolfies for sale then?
Matt
Postby paul w » 27 Mar 2008 17:36
Matt,check out fleabay from time to time,Woolfies are often on there.
I dont like the original center caps 'cos they stick out too much -
the one in the photo is from Minilite,fits a bit tight,but you wont
loose it!
Postby gaz » 27 Mar 2008 21:50
this set just got sold recently............
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=007
It rides again
mattwrigg
Postby mattwrigg » 29 Mar 2008 19:24
I quite like the look of the GT6 steel wheels. Are they the same PCD as the TR7s?
And do they do them in 14" does anyone know?
Thanks
Matt
mattwrigg
Postby mattwrigg » 29 Mar 2008 19:35
scrub that, I mean TR6 wheels.
Postby TR Tony » 29 Mar 2008 22:31
This scrapper looks like it has a set of Woolfies on it ..........
http://cgi.ebay.co.uk/The-Triumph-TR7-F ... dZViewItem
Users browsing this forum: No registered users and 41 guests
