Fitting Carpet on inner sill
DNK
Postby DNK » 24 Apr 2014 19:31
Might have to do with the lack of carpet when I got it
<font size="4">THEO</font id="size4">- What brand of sound stuff did you use?
It looks thinner
Don
Stick a Wedge In It
80 TR7 V8 Kick in the pants
darrellw
Postby darrellw » 24 Apr 2014 19:33
I thought they were part of your sound system :)
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
fastman
Postby fastman » 25 Apr 2014 00:58
This is the shot of the butle rubber/ foil sound deadening over the sills and just about everything
TR7 FHC
fastman
Postby fastman » 25 Apr 2014 01:01
Closed cell foam for extra quiet comfort under the feet and seat
TR7 FHC
Postby john 215 » 25 Apr 2014 04:23
I am with my learned friend Mr Turner, fill those sills with Waxoyl and any other cavity's you can. My FHC was Ziebarted from new and they drilled holes to fill the sills, although messy stuff I am sure it has helped preserve her.
fastman
Postby fastman » 25 Apr 2014 11:55
Agreed. The yellow FHC was ziebarted from new and the rear screen still boasts the centennial logo!
TR7 FHC
Postby busheytrader » 26 Apr 2014 15:41
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by MikeRotherham</i>
Has anyone used double sided sticky tape to stick the carpet to the inner sill and transmission tunnel?
If when using spray adhesive is it necessary to cover all the back of the carpet with adhesive or is it enough to stick just the outside edges of the carpet to the inner sill and transmission tunnel?
Regards
Mike.
I've used both methods in the past...........sticky tape - use the stuff that professional carpet fitters use, both surfaces must be clean. Contact adhesive - again use something the professionals use, not diy stuff, the spreadable stuff is more practical.
