Car very wet under drivers seat
bonnietiler
Postby bonnietiler » 12 Dec 2016 17:22
Decided to have a copurtle on the interior of the car today took the seats out..both Diaphragm's shot ,no surprise, took the carpets out and under the drivers seat it was ringing wet. No rot or anything nasty why do you reckon?
Also, I have a roll bar fitted connected at the sides with three bolts on each side now I could do with removed this for the refit but just wondered are they connected to captive nuts or how do you hold the nut whilst tightening the bolt or even the other way round if you catch my drift...
Bonnietiler
Re: Car very wet under drivers seat
Postby DNK » 12 Dec 2016 18:56
That usually happens under the passenger seat after I've taken someone for a ride...
But I digress
Stick a Wedge In It
Postby dursleyman » 13 Dec 2016 00:42
We had to make up and weld a plate with captive nuts into my car to fit the roll bar so I expect yours will be something similar if it was done properly.
Postby busheytrader » 13 Dec 2016 17:32
The roll bar could be attached by rivnuts........ I'd prefer welded captive nuts for an impact related safety item.
In the past water has entered the cabin via the door cards on the FHC. The water proof membrane wasn't put back properly after they doors were renovated.
Postby dursleyman » 13 Dec 2016 18:20
busheytrader wrote:The roll bar could be attached by rivnuts........ I'd prefer welded captive nuts for an impact related safety item.
Pretty scary if someone thought that rivnuts would be a good idea.
Milanoverde
Postby Milanoverde » 14 Dec 2016 11:35
Make sure the weep holes in the bottoms of the doors are clear. Happened to me.
Users browsing this forum: No registered users and 124 guests
