swordfishdani1960 wrote:This sounds like good advice , use a stainless steel nut and bolt
Just be careful with stainless fittings, sometimes they will effectively weld themselves together, it's called "galling". My prefered way of avoiding this is by using a lubricant on the threads before assembly, if corrosion is likely then I usually use "denso paste".
Corrosion can still occur with stainless fittings, there are many grades of stainless, the higher the grade the more resistant it is. As a quick and dirty method use a magnet, if it is magnetic then it's a cheaper grade and will rust.
