Postby FI Spyder » 21 Sep 2016 15:51
The low fuel light: there is a third wire connection at the sender by the gas tank, there is the sender itself, there is the wiring to the instrument panel (broken wire/bad connection on either end), there is a delay module on the back of the instrument panel (with it's connections) that prevents the light from flickering on and off when you get to that level and the gas is sloshing around in the tank. Without looking at the diagram I believe if you ground the wire at the sender that goes to the low light it should come on. It it does it's a sender problem. If it doesn't it's a wire/connection/delay/bulb problem.
