The rear rubber exhaust hangers have perished on my standard TR7 after only a couple of years.
Remembering the problem using the existing rubber rings the last time. The standard rubber rings part number GEX7487 were too small and had to use some from a Rover SD1 that I purchased from Rimmers part number SR34H.
The problem I have is the rear exhaust box fouls the nearside lashing point.
The exhaust is an aftermarket stainless system that the previous owner fitted. Supplied by Rimmers part number RB7021
I was wondering if anyone else had had this problem and had used an alternative exhaust hanger.
All the ones I can find aren't long enough to allow the rear box to hang low enough to clear the lashing point.
Regards
Mike.
