ballast resistor question
Posted: 06 Aug 2015 20:12
by pfenlon
I'm removing the electronic module along with the distributor an Electronic Delco unit. Car is a federal spec import from the USA, a TR7.
I have fitted a standard distributor with points again a Delco unit, unfortunately my wiring loom doesn't have the ballast resistor cable,
so I need to fit a ballast resistor, in order not to burn out the coil, can anyone tell me where I can get one for the TR7, S and S in Bacup didn't have one, are they all the same
and could a motor factor supply one?
regards Peter.
Re: ballast resistor question
Posted: 06 Aug 2015 20:45
by john 215
Hi Pete,
Generic ballast resistors are available from classic car specialists, a google search should turn up one possibly local to you. Or Ebay
I run on the V8 such as the one pictured -
Posted: 07 Aug 2015 08:54
by Steve @ SandS
pfenlon wrote:I'm removing the electronic module along with the distributor an Electronic Delco unit. Car is a federal spec import from the USA, a TR7.
regards Peter.
Hi Peter,
Good to see you yesterday. Give me a ring when you get a minute as I think I have found one for you.
Posted: 07 Aug 2015 22:46
by pfenlon
Thanks to all for their help and suggestions, I did visit G E Middleton electrical specialists in Manchester first thing this morning, and they sorted out my problem.
I bought one of 1.3/1.5 Ohms and a new coil which when wired into the ballast resistor then coil Voltage is 6 volts.
after my original post yesterday I went on the net and found a ballast resistor for a TR7 which was a 16 ohm unit, so many choices, and for the uninformed a minefield.
thanks again.
Posted: 08 Aug 2015 03:03
by sonscar
So do you still have the benefit of the 12volt override when starting?.Steve...
Posted: 08 Aug 2015 21:01
by pfenlon
Steve I haven't a clue what you are referring to. would you explain the "12v override?" please.
Fitted new resistor and coil.
12v white to one side of resistor
other side of resistor to + on coil
slate / grey and dizzy cable to -ve on coil
Hope this is OK.ImageImage
Posted: 09 Aug 2015 22:26
by sonscar
On the ballast system usually fitted there is 12volts applied to the coil during cranking to help provide a better spark.This is via a relay and associated wiring which bypasses the resistor wire which is part of the loom.If starting from scratch without this wiring already existing I would most likely just used a 12volt coil and wired accordingly.Just my opinion mind as a 6volt system has some merits.Steve..
