Battery Clock
jaybee
Battery Clock
Postby jaybee » 07 Jul 2015 16:32
Thanks for all the suggestions regarding a non-functioning clock. After removing it I found it was completely dead. I decided to replace it. However, I didn't want it to look odd so here's what I did.
First I got a battery clock movement from Maplins for £5.99. I bought a set of clock hands also. I then dismantled the Triumph clock and removed the hands and the clock face.
The centre hole in the face was enlarged so it would fit over the new spindle. It was fixed in place using sticky foam pads
Next the battery holder was cut away from the clock movement leaving the terminals exposed. A wire was soldered onto each of these terminals .
The new clock hands were cut and filed to suit and painted white, but I left the second hand red just to be different. The complete assembly was then fitted behind the instrument fascia with little strips of adhesive pad. The panel could then be refitted. There was just room to squeeze it in.
The wires were then led behind and under the dash where they were soldered to a simple battery holder also from Maplins . This could then be tucked out of sight behind the panel where the knee - pad sits. The clock was set before hand and the battery connected at the right moment. I can only adjust the clock in spring and autumn via the battery.
I'm very pleased with this little job and I hope you like the pics and the idea.
2015-07-07 16.14.16.jpg (59.08 KiB) Viewed 3335 times
2015-07-07 16.11.08.jpg (63.72 KiB) Viewed 3335 times
2015-07-07 16.06.46.jpg (74.5 KiB) Viewed 3335 times
1981 FHC in Pimento Red.
jaybee
Re: Battery Clock
Postby jaybee » 07 Jul 2015 16:33
In place in the dash
2015-07-07 16.13.16.jpg (35.41 KiB) Viewed 3334 times
Re: Battery Clock
Postby dursleyman » 08 Jul 2015 16:07
Neat idea. Just goes to show there is always a solution.
jaybee
Re: Battery Clock
Postby jaybee » 08 Jul 2015 17:36
I'm like a dog with a bone when I get an idea!
Re: Battery Clock
Postby UKPhilTR7 » 13 Jul 2015 08:09
It sure looks nice and I love the red hand :)
It is a shame that I have taken my clock out and replaced it with the oil pressure gauge.
I do like the idea that the clock battery is independent the the car battery though. I may have to look at putting the old clock back into the dash somewhere.
jaybee
Re: Battery Clock
Postby jaybee » 13 Jul 2015 23:46
Thanks Phil. I like to keep things original where I can but I also like things to work! When you think how complex the Triumph transistor clock is and how cheap and accurate modern quartz movements are. I'm glad I kept the Smiths face and it's still ticking away.
Users browsing this forum: No registered users and 79 guests
