wanted speedo pinion
Posted: 12 Jan 2015 08:25
by lyledtaylor@gmail.com
just installed 3.45 diff in my TR7 much better on the highway but need 21 tooth speedo pinion because now the speedo reads slow. Lyle.
Posted: 12 Jan 2015 13:33
by sonscar
I am unsure of this myself but are the pinion and the gear which drives it a matched pair,or is the tolerance great enough to accomodate the different diameter/pitch or whatever it is that different teeth counts have.Just interested,Steve..
Posted: 12 Jan 2015 14:54
by TR Tony
I think the 21 tooth pinion is the green one - don't have one but might help your search.
It would be the correct pinion for the 3.45 diff when used with a TR7 5 speed box fitted with the white 7 tooth output shaft worm gear.
Posted: 13 Jan 2015 05:24
by john 215
IF you have start to remove the back of the box then can be easier just to have your speedo re-calibrated, that's what I done, over twenty years ago now when I fitted a 3.08:1 CWP and been fine, should get it done again really what with the 2.84:1 living back there.
Used these gents -
http://www.speedycables.com/
Posted: 13 Jan 2015 08:14
yes the 21 tooth pinion is green and it should mesh with the existing gear.i should have mentioned it is a 5 speed box and I thought this would be the easiest way because its quite a simple job to remove the pinion.But hey guys thanks for the input. Lyle
Posted: 13 Jan 2015 09:27
Posted: 14 Jan 2015 19:41
by kstrutt1
I can confirm the green gear meshes fine with the original gear in the box, changed mine 20 odd years ago still looked fine when swapped to a new box a couple of months ago.
Posted: 22 Jan 2015 16:26
by wedgeshop
Yes they will work fine, have Green in stock.
Thanks Woody
woody@thewedgeshop.com
