A couple of problems,
Posted: 01 Aug 2014 13:58
by toneinblack
After working out the upping and lowering the roof, Ive now started to look into the oil drip that has appeared on the floor of the garage under my tr7 (dhc) It looks like its either from the sump or the crankshaft cover ( a friend said that who works a bit on cars, ) we both thought the sump sounded the easier option but looking at it , it looks just as hard to replace the sump gasket,
any traditional tr7 oil leaks in this area? also whilst the car was on the axle stands and jack , we noticed the rubber boots in the front suspension were chewed up and have ordered some more from rimmer bros, and finally ( for now ) whilst the car was up in the air we spotted 2 wires ( both blue) on both sides that were hanging loose from the cruise(?) lights, took the side covers off and no bulb holders inside and with rimmers out of stock , and also noticed rust on inside at top of front wings, looks like ive some work to do .[:0]
Posted: 01 Aug 2014 14:22
by dursleyman
One standard area for oil leaks is around the oil pump and transfer housing. The O-rings get hard after 30 years and will leak. With oil being blown around by air movement its very hard to identify the source.
Robsport sell an Oil Leak Kit for about £5 which will fix that and its a dead easy job.
http://www.ebay.co.uk/itm/Triumph-STAG- ... 43b844df57
I would suggest its worth doing that first then see if the leak is still going.
Image Image[img]http://i1040.photobucket.com/albums/b410/dursleyman/TR7%20web%20picture/IMG_0479-Optimized.jpg[img]
Posted: 01 Aug 2014 15:08
by toneinblack
thanks for the reply, would that be gearbox end of the engine?
Posted: 01 Aug 2014 17:09
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by toneinblack</i>
They are on the lower right rear corner/side of the engine. I replaced these O rings when I first bought my car and it cured 90% of my oil leaks.
Posted: 01 Aug 2014 18:10
by toneinblack
thank you FI Spyder , will get that sorted and hopefully cure the drip.
Posted: 01 Aug 2014 23:11
Clean out the gearbox subframe before you start trying to stop a few drips of oil on your floor.
I changed the gearbox oil to Penrite manual transmission oil from auto transmission fluid, about 6 months & a few thousand kilometers or more ago. I did not wash out the subframe.
At the same time I washed the drip trays from under the car. I am still getting a few drips of ATF in the gearbox drip tray, & as yet no Penrite oil.
When I noticed this I decided to let it go, to see how long it took to stop.
I do worry occasionally about the engine. There has not been a single drip of oil from it since it was rebuilt. Now we all know that is just not right for a Triumph.
