Starter help!
Posted: 06 Jul 2014 18:38
by gregtheo
Hello everyone, I've just finished fitting a replacement 2L engine to my '78 TR7 but I cant get it to turn over.
Has someone got a clear diagram of where the wires go on the starter please? The starter relay is clicking but no life from the starter or the solenoid.
Problem is I didn't take a photo of where the wires went before I pulled the old engine out.
Any help would be great as I need the car running asap as its my daily drive!!
Thanks
Greg
Inca yellow '78 2.0 FHC (in bits...again!)
Posted: 06 Jul 2014 19:23
by gregtheo
Right, have narrowed the problem down to no power on the ignition switch wire. I'm thinking possibly knackered starter relay?
Greg
Posted: 06 Jul 2014 19:38
by Workshop Help
Just for fun, is your battery fully charged and are the terminal posts clean? Don't forget the main ground next to the battery as well.
Posted: 06 Jul 2014 19:48
by gregtheo
Battery came straight off the charger and into the car! Cleaned the terminals as well.
The engine turns over fine if I bridge the positive and the ignition terminal so I assume its the ignition circuit somewhere?
Posted: 06 Jul 2014 20:24
1. Check the connections as suggested above. Mine had a duff solenoid connection (the wire was green inside the spade connector and I got no more than a click at times). Cut back the cable and remade the connector and all was OK.
2. Try bridging across from the big starter connection to the solenoid connection with a screwdriver. If the solenoid is OK it will pull in. Mind you, a click from the starter solenoid does not mean it is working unless you have put a meter on the solenoid end to check. Had to start my car this way when I first got it as the starter relay was U/S. You could also check the solenoid by taking the cap off and manually operating the relay (did this also for a while).
Posted: 06 Jul 2014 20:47
by johnny5
I had this problem when I fitted an engine in my white FHC. I tracked the fault to the engine bay wire harness, there was a break in the wire that connects the starter relay to the starter motor solenoid.
80 DHC Green
77 FHC White
Posted: 07 Jul 2014 00:28
I've had a problem with the connector block to the starter relay being dirty (spray with contact cleaner). Also ignition switch not making contact (flush ignition switch with silicone spray to clean out previously sprayed graphite that was sprayed in there.. (also happened to my Integra).
Posted: 07 Jul 2014 04:22
by john 215
As well as what everyone else say's check the main earth in tight to the engine, often overlooked when refitting an engine [:I]. Although if loose the choke cable will glow a nice red colour [B)]
Also there is a harness connector just inside the car, N/S/F footwell that is the connector for engine loom make sure that is good.
One further connector is the gearbox loom connector, has a bridge wire in it for starter, if a manual box or goes to inhibitor switch if auto.
Good luck,
Posted: 07 Jul 2014 09:10
by Jerryopenair
I had a problem with the starter, turns out it was the starter relay terminal burnt out, it's generally the blue relay, if you take the cover off you may see the terminal burnt out, if so carefully remove the spring and then you can clean up the terminal. I replaced mine anyway.
Posted: 07 Jul 2014 10:55
by Jerryopenair
Brain not working. Where I've typed terminal replace with contact
Posted: 07 Jul 2014 19:15
by gregtheo
Thanks for everyone's help! Its much appreciated!
Problem is now solved, it was the wiring under the dash, one of them had pulled out of the big plug, engine now turns over! Now to try to get it to start!
Thanks
Greg
Posted: 09 Jul 2014 15:13
by bmcecosse
Posted: 10 Jul 2014 10:51
by gregtheo
I span it over on the starter with the plugs out waiting for the oil pressure light to go out, it never went out so I changed the oil pressure switch, still no oil pressure so I thought maybe a dodgy pump, took the old pump off and the shaft that drives it was totally missing! Couldn't believe it! Fitted spare pump and shaft and the oil light went out after a few seconds! Fitted the plugs back in the engine and it started first turn of the key!
Greg
Posted: 12 Jul 2014 10:43
by bmcecosse
Posted: 14 Jul 2014 18:23
by gregtheo
Definitely! Cant think of any reason why that part was missing but its sorted now!
Greg
