Strange engine noise
Posted: 19 Jun 2014 14:06
Hello all,
I just completed a complete overhaul on a 2.0 and it has a noise that is baffling me. Best way to describe it is a howl or squeal similar to a fan belt or bad alternator bearing. However I took the belt off and it's still there. The baffling part is it only does this for a matter of several minutes when started from cold. Once the engine is up to normal temp, it goes away like turning off a switch and sounds absolutely perfect. It didn't do it on the initial fire up but is now there after it sits and completely cools....such as overnight.
The head was rebuilt by a competent local shop. Rings and bearings were replaced, crank ground .010 as well as timing chain/guides/tensioner etc. I've driven it enough miles that if something were wrong with the basic rebuild, it should have got worse or failed by now.
I was thinking possibly the waterpump??? Or should I say I hope that's all it is. I re-installed the original as it wasn't leaking and I wasn't sure of quality of replacements. Any thoughts or experiences like this? Thanks
Jim Underwood
Jim Underwood
