HELP - High RPM's when starting / idle
Posted: 19 May 2014 13:21
by KFSullivan
Hello to All -
My son and I finally finished our winter project which was to rebuild the water pump which had started leaking last fall. In the end we bought a new pump and finally got it installed several weeks ago. Upon start-up, everything seemed pretty tight and we had no leakage. We took it out for a test drive and all was well. A few days later my son took it out for a drive and he sprang a leak.
We found that one of the small heater hoses at the back of the engine had split open. This of course is the one that is only a few inches long and is under and behind the intake manifold. So once again we disconnected everything and removed the manifold to replace this short piece of hose. When we got everything put back together, we started the car which started right up, but the engine immediately went into race mode as it was hitting a constant 3,500 rpm's.
At first I thought the accelerator was stuck, but upon inspection, it was not. All of the springs up by the carbs are where they should be and the idle screws are almost all the way out as they were before we replaced the hose.
I guessing a vacuum hose is disconnected, but we cannot seem to see anything that is out of place. I'm also surprised that a disconnected hose would result in such a high idle.
As always, your help and assistance will be greatly appreciated.
Thanks! [:)]
1980 DHC Pagaent Blue
Posted: 20 May 2014 16:03
by nick
Did you use a new intake manifold gasket or reuse the old?
nick
'79 TR7 DHC
'76 TR7 FHC
Posted: 20 May 2014 20:40
by KFSullivan
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by nick</i>
nick
'79 TR7 DHC
'76 TR7 FHC
We did install a new one when we replaced the water pump which was only a few weeks before and very little run time.
Thanks.
Posted: 21 May 2014 08:17
Did you check the carburettor linkages are fitted correctly ?
Posted: 22 May 2014 01:21
by KFSullivan
[<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Yes I did. The carbs did not come off the intake, so we didn't remove the linkage.
Still trying to figure this out.....[?]
Posted: 22 May 2014 01:40
by scarface031
The engine sounds like it is getting too much air. Do you have SU HS6s?
-Justin P
Posted: 22 May 2014 20:29
by KFSullivan
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by scarface031</i>
-Justin P
No, are carbs are ZS's.
Posted: 22 May 2014 22:52
Try spraying WD40 or equivalent all round the carb rubber mounts, & any gaskets or air hoses that were disconnected.
You may have leant on the carbs & split the rubber mounts, & old hoses have a tendency to split when mucked about with.
If no luck, start blocking off hoses at the manifold/carb end to eliminate them as the problem.
Could any ancillary bits of the carbs have been bent or jammed. I once had a sticking choke on an SU after the manifold & carbs had come off a car as a unit.
I finally found a slightly bent jet tube, & although neither I, or the bloke helping me could remember dropping them, or even putting them down too hard, one of us must have.
