Passenger door
Posted: 02 Apr 2014 19:44
by porterdave
Hello guys wondering if you could help solve a problem I have with the door. What happens is that when I go over pot holes etc rough ground the door seems to jump,the door hasn't dropped or anything, what do I need to adjust to stop it happening
cheers
Dave
Posted: 03 Apr 2014 12:47
by Workshop Help
Here's smart alec response. Use your steering wheel to drive only on the smooth parts of the road.
Now for the non smart alec response. Check the door hinges for tightness as well as the latch mechanism.
Posted: 03 Apr 2014 14:55
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by porterdave</i>
... when I go over pot holes etc rough ground the door seems to jump ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
DHC or FHC body style?
Posted: 04 Apr 2014 22:30
by porterdave
Its the DHC, the wifes refusing to get in till door is sorted (don't know if that's a good thing or not )
Posted: 04 Apr 2014 23:36
by DNK
Did you clean the anti burst latches
Don
Stick a Wedge In It
80 TR7 V8 Kick in the pants
Posted: 05 Apr 2014 01:32
Have you checked the pins in the hinges for wear?
How is the metal in the A post & the door frame, where the hinges, catches & the anti burst fittings attach?
Let the lady drive, & you sit by the doubtful door, chewing your finger nails, for what ever reason.
Posted: 06 Apr 2014 08:28
by claypole1360
You could weld up the door and tell the missus she has to jump in Daisy Duke style, just think how much stronger your shell would be if you welded both doors.[:D]
1978 TR7V8 FHC
1962 Herald Coupe 1200
1989 Peugeot 205 xs
2003 Peugeot 206 GTI
2009 VW Passat
Posted: 06 Apr 2014 13:42
Does the door rattle or is there visible movement on rough roads between the quarter lights and the windscreen frame?
Excessive movement may point to weakening of the cars structure.
