Brake pressure differential piston/switch question
Posted: 03 Mar 2014 21:14
So I rebuilt my master brake cylinder.
For those of you with knowledge about the inner workings, I am curious how the pressure differential piston works. I know it moves and releases pressure on the switch, but which way does it move?
When I put it back in I noticed that it seats without brake fluid pressure in the exact spot to line up with the pressure switch. Is that normal?
How can I test it to make sure it is working?
Thanks,
Sean
SF Roth
Thanks,
Sean
SF Roth
