Where to buy the trim piece around window crank?
Posted: 28 Jan 2014 14:50
by Sean Roth
I put in a new window crank, but there is a little gap where a trim piece goes around the center circular area where the crank attached via screw.
I can't find that trim piece anywhere...
SF Roth
Posted: 28 Jan 2014 15:05
by Neil_W
You can get them new - at a price [:0]
http://www.rimmerbros.co.uk/Item--i-GRID006262
Have you fitted the sponge between the crank & inner side of the trim panel ?
That will close gap but if plastic round part between handle & trim is the part you are after - you'll have a gap.
Try 2nd hand from S & S or Robsport
Posted: 28 Jan 2014 16:29
by Sean Roth
Hi, thanks for the info. I ordered the sponge and the trim circle.
$32 total, expensive but it will last me forever and look better.
Thanks!
Sean
SF Roth
