Camshaft sprocket locating pin?
Posted: 12 Nov 2013 17:23
by motman
Once again I'm in need of some expert TR7 help.
I mentioned a while ago about my 77 2.0litre TR7 making a tapping noise which I suspected was the timing chain. I have finaly got round to taking the rocker box off and having a look, the first thing I spotted was a bolt in the centre of the camsprocket which is rattling about loose. I believe its called the camshaft sprocket locating pin, it wont tighten up and has clearly been hitting the plate infront of it.
Any ideas if its a common problem and more importantly what the fix is?
Posted: 12 Nov 2013 18:01
Remove the bolt immediately, it should only be fitted when removing the camshaft, to support the cam sprocket.
You're lucky that it didn't come of and ruined your chain
Support bracket should be free from the cam sprocket, as this picture shows ...
</font id="blue"><b>[url="http://www.tr7beans.blogspot.com/"]<u><b><font size="3"><font color="red">My full Weblog</font id="red"></font id="size3"></b></u>[/url]</b></i></center>
Posted: 12 Nov 2013 19:10
by motman
So some pillock has left that in after doing some engine work?
Oh dear, that casts serious doubt over the quality of work that has been done!
I did try to remove it but its not for coming out. Now I'm very worried about my engine......
Thanks for the info Beans, much appreciated
Posted: 12 Nov 2013 19:19
He could have forgotten to remove it after work, happened to me once [:I]
I was Lucky to notice I was missing the nut in my micrometer case, where I always store it, so no harm done.
Posted: 12 Nov 2013 20:15
by Workshop Help
If you would, pretty please, take a photo of this disaster in the making. I'm having trouble visualizing it.
Posted: 13 Nov 2013 04:52
by john 215
How it <u><b><font color="red">SHOULD NOT</font id="red"></b></u> look -
The nut is the same size thread as the cam bearing caps, I would check they are still present [:0] [xx(]
Posted: 13 Nov 2013 12:18
by motman
I will post a pic later but I have spoken to S&S as I cannot get the bolt out and they tell me its part of the cam gear thats come adrift. Looking at the pic of Beans its the center part of the cam sprocket, the threaded bit with the nut on you can see sticking out, its this that is loose.
It seems this should be tight up against the sprocket and the locating tool fastens to it?
Posted: 13 Nov 2013 13:39
Sorry misread your initial post, thought there was a nut + bolt screwed to the support bracket.
The "nut" and "bolt in my picture both are not what the appear to be;
• The bolt is a dowel for centring the sprocket to the camshaft.
• And what looks like a nut isn't treaded but press-fitted to the dowel to keep it in place.
As it should look from behind with the cam shaft removed ...
Posted: 13 Nov 2013 14:24
by motman
In that case its the dowel that has come adrift and is rattling about. Looks like its going to be a full chain off, camshaft out stripdown.
i just hope I can save the cam or S&S have a good used one as I don't want a repo item on it
Posted: 13 Nov 2013 17:22
by Neil_W
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by motman</i>
Robsport has some new old stock camshafts a while back - they were about £30 & just needed a polish of cams - they may have some left [?]
Posted: 13 Nov 2013 21:19
by nick
Not so fast. My recollection is that the nut does not tighten snugly. Take a look at this drawing before you do anything drastic.
http://www.rimmerbros.co.uk/Item--i-GRID006038
nick
'79 TR7 DHC
'76 TR7 FHC
Posted: 14 Nov 2013 05:40
by motman
On the drawing its 149787 that is loose but its not just the nut, its the whole thing. The plate in front of it has also taken a beating and is now very out of shape. As the dowels only function appears to be to hold the chain assembly on head removal I think I could probably do away with it but I suspect the only way to remove it is going to be to remove the chain and timing gear.
Posted: 14 Nov 2013 09:24
by motman
[url="http://s31.photobucket.com/user/mot-man/media/P1030398-Copy_zps3dbd0636.jpg.html"]Image[/url]
Posted: 14 Nov 2013 12:06
by Neil_W
Have a look at the Work Manual Page 86 for more details on the bolt - temp. measure 'cut it off' ?
http://www.tr7.co.uk/pdfs/TR7.pdf
Posted: 14 Nov 2013 17:24
On the drawing its 149787 that is loose ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Looks much the same as the one on my (Sprint) engine)
Bracket is bend a bit, but that shouldn't matter much,
as long as you don't need it to mount the sprocket wheel.
