Locked Out
Posted: 09 Nov 2013 22:09
by piperff
Driver door won't open
Have removed panel and have access
Lifted Lever to release latch
Spent some time observing Passenger side action
Still can't get'er open...Any Ideas...Thanks
Posted: 09 Nov 2013 22:14
I assume it's a DHC. Likely the anti burst latch stuck. Check other side. There is a slide block on the B post that should be lubricated. On drivers side have some one hod the latch open while you give a good boot from the inside with your heel. Don't hurt yourself. When it's open lube it.
It's come up lots. You can use search in upper right corner to see past posts.
Posted: 09 Nov 2013 22:39
by piperff
Thanks, spent all afternoon no luck
5 min. on this forum BINGO
Lock opened .....Again Thanks,[:D]
