<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by g4zur</i>
Russ did you remove dash to change gauge or from underneath.
Thanks
Gareth
G.P.Albrighton
Gareth, you can do it without removing the instrument cluster but you need to remove clear screen and the mask to get access to the gauges.
You have to take off the drivers side top of the dash and the column shroud. There are several "hidden" screws so have a look at your manual to find them. When those are off there are three funny headed screws that hold the clear screen, the mask lifts out and the instruments are right there. A couple more of those funny screws hold the gauge which is just pushed in with three terminals.
I did it originaly to change the bulbs to LED's and then again to fit an oil pressure gauge in place of the clock and now just done the fuel gauge. It gets easier each time!
1980 TR7 Sprint DHC
