When I uprated my front brakes I also fitted 4 speed cylinders to the rear, as recommended by the guys at S&S. "A little extra braking effort at the back since there's a lot more at the front". I couldn't tell you how much extra braking effort these cylinders make since everything was changed at once. The MOT man is impressed each year.
It was a straight replacement but as Dursley said a tiny hole (2.5mm?) has to be drilled in the backplate to accomadate the locating pin. Simples....
The rear brakes have never locked up, even when I've locked the front up in the wet and that takes some doing.
I wouldn't have changed the rear cylinders if I hadn't uprated the front brakes first.............I found them pretty poor and they locked up under spirited driving in the dry all too readily.
