Front wheel bearing
Front wheel bearing
Postby bmcecosse » 30 Sep 2013 09:53
Having detected a tiny roughness in a front hub, I stripped it out and found a small taper roller bearing on the outer, and a much larger taper roller on the inner. What madness made them fit such different size bearings? They both have to carry the same load - and of course, the small outer is showing some wear, the inner is perfect. Does anyone know the ref number for just a new outer bearing?
Postby saabfast » 30 Sep 2013 11:05
The arrangement is pretty much standard on all the taper bearing cars I have worked on in the past (although they are mainly BL and Vauxhall). Had Marina years ago which seemed to develop a rumble after about 3000 miles and sent the bearings back the first time (Moprod) but they said there was nothing wrong with them, so I just changed them regularly.
As far as I know they come in pairs for a wheel unless you want to go to a bearing specialist (SKF agent?) and just get the small one matched. They are only about £10 a set.
Saab 9000 2.3 LPT Auto
Mark H
Postby Mark H » 30 Sep 2013 16:09
It seems there is a permanent fix :
[url="http://www.tsimportedautomotive.com/tr7_tr8.html"]TSI Catalog[/url]
1980 TR8, coming back to life
Postby jclay (RIP 2018) » 30 Sep 2013 18:40
Be aware that TSI hubs do NOT come with studs! You will have to press out your old ones and press them into the TSI hubs. You will also have to press in the races for the bearings.
Postby jclay (RIP 2018) » 30 Sep 2013 18:42
You might also want to look at these:
http://www.hamilton-motorsport.co.uk/acatalog/TR7_8_Alloy_Front_Hub.html
Postby Beans » 30 Sep 2013 19:32
Just make sure you use proper quality bearings and fit them correctly,
And yes, they are not cheap! Even at max. discount they still cost between €30,-- and €40,-- each.
SKF number for the outer bearing is LM 11749/710/Q, inner bearing is L 44649/610/Q.
Seal is a standard automotive item.
p.s. SKF has a policy of changing their numbers from time to time, so its advisory to get one of their printed catalogues/handbooks, so you can search on the actual dimensions.
Mark H
Postby Mark H » 30 Sep 2013 20:21
What do you think about the issue of adjustment? I've always been suspicious of the large amount of play they tell you to put in the bearings, to allow for thermal expansion. Bearings hate to run without preload and I suspect that a lot of the wear is happening before they warm up.
On the Jaguar XJS the current wisdom is to adjust out the slack, and this seems to have reduced, not increased, the number of failures.
HDRider
Postby HDRider » 30 Sep 2013 22:17
I think that the correct preload is 5 foot pounds for the front bearings.
Smaller outer bearings is definativly the standard for any car that I have worked on. The inner bearing is centered on the wheel and carries most of the weight. The outer bearing is more for side load and stabilization.
Edward Hamer
Petaluma CA
Postby Beans » 01 Oct 2013 15:43
Tighten the nut till you just can't turn the hub by hand anymore.
Than slack of the nut a little till the hub just starts to move freely.
Postby bmcecosse » 01 Oct 2013 19:35
Thanks all - these are taper roller bearings - BOTH bearings must carry equal load. They are exactly the Marina bearings - I suspect they are Marina hubs, and discs!! I fitted a new set - had to nip them up slightly after a test run, and after a second test run they are fine as they are - spinning easily, yet no detectable play.
Postby busheytrader » 06 Oct 2013 09:26
At least they are reasonably easy to replace at home. My son's last 2 cars needed their rear bearings replaced with the help of a 10 tonne press. Not the sort of thing I have lying around.
My belated Golf Gti needed the races drifted into the rear discs, the front ones were sealed for life and needed a whole replacement unit if they wore out.
Postby bmcecosse » 08 Oct 2013 17:40
Indeed! A brass drift and 'wee heavy' hammer did the job in minutes.
Postby Beans » 08 Oct 2013 19:36
Indeed! A brass drift and 'wee heavy' hammer did the job in minutes...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Must have item indeed [;)]
