SAE 30R7 is rated to 50lbs pressure but is not recommended for ethanol blends - it would be fine if you are able to use only "straight" petrol.
SAE 30R9 is for use with ethanol blends, biodiesel, etc as well as having 180 lb pressure rating for EFI. If you have to use an ethanol blend then this is the one to get.
And if any part of the hose is submerged in fuel, such as part of an "in tank" pump, then SAE R10 is required where the exterior of the hose will not be damaged by the fuel it sits in.
