So - is there any dis-advantage running a diesel oil all the time?
In an older or higher mileage engine that may have a build up of carbon or sludge then there could be a risk of loosening too much of the built up deposits which could then be carried round the engine clogging oilways, the filter or oil pick up screen.
In a newer engine that should not be a problem.
Bear in mind that there are many oils with higher detergent levels than our traditional mineral 20/50, usually ester based synthetics for example Mobil 1 10W60 which I believe also has a good zinc level.
