Fuel injection tr 7- 2.0
Stag76
Postby Stag76 » 21 Mar 2014 06:31
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Great piece of engineering and problem solving, I assume you are using a M.A.P. sensor rather than air flow meter ?
Yes, the MAP sensor is incorporated in the MegaSquirt Board. You can also program using TPS/RPM or MAF/RPM.
Is that FI Sprint Motor the one in the F3(?) car at Gaydon...I think I saw it there last time I visited.
TR7 Convertible
Sprint Motor
MegaSquirt EFI
HDRider
Postby HDRider » 22 Mar 2014 17:49
>>>it’s your belief the sevens or eights Boshc - banked fuel system, >>>designed 30+ years ago is more efficient or better or even equal >>>to a modern sequential multiport systems…what can I say?
No I don't think that at all. My point is that modifying a TR7/8 injection system to a sequential multi port and not changing anything else will make no real difference except to the smoothness of the idle.
I am quite aware that modern engine management systems create huge advantages in HP and economy but not only are they sequential they adjust ignition timing, valve timing, adjust the mixture, learn your driving habits,turn cylinders on/off and God (and the EPA) only knows what else.
Edward Hamer
frankman
Postby frankman » 25 Mar 2014 08:43
..So for a classic vehicle should the carburettor or injection also look a little classical -
so I would rather take the Jenvey solution - in silver, which fits into the time [8D]
http://qedmotorsport.co.uk/qed-shop/view-all-products-in-shop?keyword1=weber%20throttle%20bodies
This Guy I know http://www.newa-racing.ch/index.html
Hello from Switzerland
Frank
