Clutch Fork Question
Postby FI Spyder » 23 Jan 2014 17:12
I already had two studs there as part of the attaching mechanism but they weren't precise enough to get the shaft started.
Stag76
Postby Stag76 » 25 Jan 2014 06:05
I made this simple tilting table that attaches to an engine crane. Lift the car on the hoist, strap the gearbox to the table, tilt and lift it into place.
TR7 Convertible
Sprint Motor
MegaSquirt EFI
Postby Hasbeen » 25 Jan 2014 07:08
Wow, that is nice Stag.
It shows the difference between you & me.
I make up a slightly shonky cradle to go on the floor jack, [which sort of worked], while you produce a thing of beauty.
whitenviro
Postby whitenviro » 25 Jan 2014 16:26
Wow: I am basically trying to find enough pieces of 2x4 to build a little cradle that will sit on top of a jack. And trying to get enough blocks together to get the car high enough off the ground. But at least its in a garage with a concrete floor. The last clutch I did I had to shovel the snow off that car and lay on ice the whole time I was under it. Not fun.
[/img]
Postby nick » 25 Jan 2014 23:00
Here is another variation for lifting the gearbox to the correct height to align with the engine. You work the crane through the hole in the tunnel.
Image[/URL]
'79 TR7 DHC
'76 TR7 FHC
Postby Workshop Help » 26 Jan 2014 02:11
Nick, shame on you! This is just plain cheating.
Stag76
Postby Stag76 » 26 Jan 2014 06:31
Hi Phil,
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">It shows the difference between you & me.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
It shows who is the smart one...I has probably half way through dreaming how it would work and you already had the job finished.
TR7 Convertible
Sprint Motor
MegaSquirt EFI
Postby FI Spyder » 26 Jan 2014 12:59
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by nick</i>
Wow, that's got to be like assembling a ship in a bottle using a construction crane.[:p]
I'd try that with a Spitfire were you can lower the whole transmission in from the top through the huge transmission tunnel but I wouldn't try it myself.
whitenviro
Postby whitenviro » 27 Jan 2014 00:53
So what could possibly go wrong? I opened the box from my clutch kit to find a Borg & Beck pressure plate, and a Japanese Aisin clutch disc with the wrong spline, for a main shaft about a quarter inch bigger than the TR7. Not even close. "Oops How did that get in there? We'll send you the right disc as soon as possible."
[/img]
Postby Cobber » 27 Jan 2014 10:11
Doubled up the message for some reason?
Postby Cobber » 27 Jan 2014 10:13
I've always used this method for removing and refitting the gearbox/transfer case assemblies form Landrovers S1, S2 and S3.
'98 MG-F, 69'Ford F250.
