Postby Cobber » 20 Apr 2016 22:42
The number of carbs has nothing to do with reliability, and it's doubtful it would do anything for economy either.
Californian versions had a single ZS carb, to comply with the strict emissions regulations in that state, by most accounts they were slower that a wet week at Port Welshpool!
The buggerising about you'd need to do inorder find which metering needle and jet required to get a single SU to run properly will make you want to crush the car! You'll only be able to get it to run properly on a dyno, you may as well pay a carbie expert to do the carbies for you it would be cheaper than all the stuffing about, only to end up with a sportscar with no sport in it
'80 Triumph TR7.
'98 MG-F.
'83 Jaguar XJ6 Sovereign S3.
