Sorry, I don't know where the relay is kept.
I had exactly the same problem when I fitted the V8 engine into mine. It had the Opus electronic distributor fitted to the Rover SD1 at the same time as our cars.
As soon as my newly converted TR7V8 reached operating temperature the sparks and rev- counter would drop to zero. This was common to these electronic items back in the day but once cooled down it would work until it warmed up again.
Hopefully the affected relay is one of the common types used in many parts of the wedge.
TR7 V8 DHC Jaguar Solent Blue. 9.35cr Range Rover V8, Holley 390cfm, JWR Dual Port, 214 Cam, Lumention, Tubular Manifolds, S/S Single Pipe Exh, 3.08 Rear, 200lb Spax & PolyBushes all round, Anti- Dive, Strut-Top Roller Bearings, Capri Vented Discs & Calipers, Braided Hoses, 4 Speed Rear Cylinders, Uprated Master Cylinder & Servo, AT 14" 5 Spokes or Maestro Turbo 15" Alloys, Cruise Lights, S/S Heater Pipes, Replacement Fuel Tank. No Door Stickers. Mine since July 1986, V8 from 1991 courtesy of S&S V8 conversion kit (built not bought) and big brake kit.
