While some have done it with out, I would remove the rear axle. It's tough enough with it out. With it out I would seal it regardless with POR-15 sealing kit. After my sealed tank failed and started flaking off I don't trust any other sealing methods. The one caveat is the sealer needs to be fully drained to properly cure. That means you have to get a shop to weld in a bung in a corner as the hole(s) are not the low point. With the axle out you can:
1. Replace rubber bushings with poly.
2. Spray all areas above the tank with wax oil product.
3. Turn the diff upside down to fully drain the old oil and put new in (with some STP).
4, POR-15 THE REAR AXLE.
5, Polish the brake lines so they look pretty.
6. Replace the rear brake flex line with braided steel.
As you can tell I believe in doing once, doing it right, doing it once (I know I said that already).
Sealing tank slide show:
http://s119.photobucket.com/user/Spit999/slideshow/TR7/Sealing%20Gas%20Tank
Gas Tank Bung.
