Are those the pipes that feed fresh air into the exhaust side of the cylinder head to keep down the emissions?
When I bought my range rover engine for my V8 conversion, I had one fitted to each cylinder head. I was advised to ditch them but keep the threaded fittings for use with 8mm ball bearings to seal the redundant vent holes. No issues with removing these in the UK.
