Gearbox inspection
whitenviro
Gearbox inspection
Postby whitenviro » 10 Jan 2014 04:06
I've been going over the spare engine and five speed gearbox I picked up in Vancouver. Much to my surprise the gearbox looks to have been rebuilt; all of the gaskets show a fairly recent silicone gasket sealant that isn't original. The mainshaft splines are perfect, with no wear and there was only a tiny bit of swarf on the drain plug. It goes into all gears nicely. I'm considering using this gearbox when I replace the clutch and fork on my car; embarrassed to say, its still sitting in the garage right where the tow truck dropped it in October.
I don't want to put too much time into this box because its just a spare that I didn't even plan to get. It just sort of happened.[:D] But what simple checks should I do on it to be sure its alright?
[/img]
Postby FI Spyder » 10 Jan 2014 13:50
Other than end float that Beans has mentioned in another recent post I don't think there is much you can tell other than installing it and trying it in actual driving situation. (other than tearing it apart to look at gear condition.
nick
Postby nick » 10 Jan 2014 16:36
I recently installed a used box after changing the pump and seals. One seal that seems to be trouble is the small "O" ring that fits into a groove in the case where the selector shaft enters. My parts catalogs show it as not available. I have done two of these boxes and bought the "O" ring at Ace Hardware. One of them sealed perfectly the other is leaking. I'm not sure I bought the same size each time. Problem is that you can't tell if they will leak until you run them. I'm going to try and change my leaker in situ.
nick
'79 TR7 DHC
'76 TR7 FHC
Users browsing this forum: No registered users and 36 guests
