Hi All.
Fitted accuspark electronic ignition last week, along with their blue coil, new plugs and leads, distributor cap and rotor arm, more or less a new ignition system. Started fine, timing light used set at 10deg BTDC, I believe this is correct at 800/900 RPM. Runs great. Starts well, This is the query, Now when engine up to temp. the idle RPM has jumped up to 1100 RPM. All the time.
Is this to be expected?
Many thanks to Russ for loan of the Dizzy Spanner.
Regards Gareth.
g.p.albrighton
