The Dreaded Clutch Problems
Posted: 07 Jun 2009 08:54
by moestr7v8
On Tuesday just got home in the V8 and I lost the clutch, checked the fluid,empty,so I changed the old master cylinder put new seals in then the same with the slave cylinder put it all back and tried bleeding the system,that worked fine no air bubbles,locked it up tried the clutch pedal and it moves about a quarter travel and then it is solid tried several times over still the same effect.
What am I doing wrong any help on this will be very much appreciated [;)]
Moe
Posted: 07 Jun 2009 09:02
by PeterTR7V8
Remove the slave cylinder & confirm that the pedal has full travel. If that is OK it could be the bits inside the bellhousing. Can you get under the car, remove the inspection cover (if you have one) & confirm that the pushrod, fork & release bearing are connected correctly.
Posted: 07 Jun 2009 09:15
by moestr7v8
Thanks for the reply Peter,yes the pedal has full travel without any fluid in the master cylinder,I also pulled the slave cylinder out,left the fluid pipe connected pushed the piston back depressed the clutch pedal and I had movement on the slave piston, I will check it out underneath for an inspection panel but I am pretty sure there is not one.
Moe
Posted: 07 Jun 2009 09:24
by Ianftr8
Hi Moe,
Take great care when looking and pushing things around on the clutch lever as they have a habbit of falling apart and then its a gearbox out job!
I managed to get my master and slave cylinder off the car with the pipe connected the other week and was able to Bench test the system with it hanging in the garage - it may be something like a seal caught up or not straight.
Ian
Ian Freeman
1962 Triumph Courier
Posted: 07 Jun 2009 10:00
by PeterTR7V8
On the V8 half of the gearbox bellhousing is left exposed & the inspection plate is a 1/2 circle piece of metal that bolts onto the underneath of the motor to cover the part of the bellhousing that isn't covered by the back of the engine. Sometimes the plate moves on to a better life in another garage. I don't know if it is better to have one but I'm sure mine is the source of an annoying rattle.
Posted: 07 Jun 2009 10:11
by Steve @ SandS
Either the pivot pin has gone through the clutch fork or(more likely) when you removed the slave the fork was pulled off the pivot pin.
Unfortunately it is gearbox out either way.
Steve @ S&S Preparations
Posted: 07 Jun 2009 10:24
by moestr7v8
Hi Peter I have had a look underneath and there is an inspection hole there but I just can't get underneath far enough to see pivot pin.
Ian and Steve thanks for the info, that's the job I did not want to do [:(]I will try and see if I can get further under the car to see in the inspection hole and hope!!!!!!!!!
Moe
Posted: 07 Jun 2009 12:46
by Workshop Help
You will be pleased to know one of my recent articles is here for you. Search the forum for it. One has to wonder, did you hone the slave cylinder and then polish it to a mirror finish? As for the clutch pushrod, after removing the slave cylinder, is the pushrod still attached to the pivot fork?
Posted: 07 Jun 2009 16:16
by moestr7v8
Thanks Mildred,Peter,Ian and Steve what it looks like is the pivot pin has gone through the release arm so as Steve said it is a gearbox out job.
Thanks for all your advise and help on this problem [;)]
Moe
Posted: 07 Jun 2009 18:43
by wedggie perrin
<b>Bugger!</b>
Posted: 07 Jun 2009 22:43
by bmcecosse
Is there absolutely no way to hook this all back together - without removing the gearbox? Perhaps cut 2" diam access hole(s) in the bellhousing with a hole-saw - to get at the parts ?
Image Image ImageImage
Posted: 07 Jun 2009 23:46
by TR7Aaron
I just removed a 5 speed tranny from my 1980 parts car. If you need some pictures of it to maybe form an alternate plan of action rather than taking out the tranny, let me know and I'll post them asap.
Aaron
Posted: 08 Jun 2009 01:20
[quote].............the pivot pin has gone through the release arm so as Steve said it is a gearbox out job.
Exactly what happened to me many years ago. [:(] The clutch pedal went all the way down to the bottom and when it returned back up it locked up solid. Luckily I was 20 yards from home. 2.0L engine and gearbox out, V8 plus gearbox and S&S conversion back in[:)]9 months later.
But you've already got a V8.
Posted: 08 Jun 2009 04:32
by PeterTR7V8
With a hoist, a good toolkit & a determined attitude you can extract the gearbox in 2 hours. With no hoist & a couple of unco-operative bolts it could take all day. It may make more sense to get it to a workshop.
Hmm, what about putting the car on jack stands & removing the sump to give you access to the open bottom half of the bellhousing.
Posted: 08 Jun 2009 06:47
by Steve @ SandS
Wouldn't work, the flywheel will still be in the way.Only way is exhaust off and drop the gearbox.
