Engine bay wiring
Posted: 29 May 2009 17:55
<font face="Comic Sans MS"><font size="2"><font color="blue">Okay, trying to connect all the spaghetti in the engine bay and not doing too bad, BUT pride comes before a fall.
The loom that connects to the alternator has two "spurs" that connect to the coil. (There is also the oil pressure connection, but that one's sorted).
One of these spurs has two seperate cables, one white and yellow (WY) and one white and slate (WS). I have connected the WY cable to the +ve terminal and the WS cable to the -ve terminal, as identified from the wiring diagram in my Haynes manual.
There is another spur that has two cables into one termination, both WS. I think this connects to the -ve terminal. I've also connected the condensor to the -ve termnal.
The reason I'm querying is that I have 4 connections on the -ve terminal (condensor, twin WS cable and single WS cable) but only one (WY) on the +ve terminal. It just appears "lop-sided" to me so I thought I'd check with you guys.
Can anybody shed any light on this, as I'd like to make sure it's right before I run any electricity through and set fire to The Pheonix! I don't want any more ashes, thank you very much!
I might be able to get a photo on-line within a couple of days, but if you can help me before then, obviously it'd be much appreciated.
Cheers again,
Mac.
</font id="blue"></font id="size2"></font id="Comic Sans MS">
Cheers again,
Mac.
