On-Line NGK Spark Plug Selector
Posted: 24 May 2009 07:28
How many of us walk into a motor factor and asked for a set of plugs to suit a TR7 or a 1985 Range Rover (I have to for the V8), and walk away with what we're given? I did this last year.
Last month I had some problems with the engine stuttering under acceleration at low revs in 4th or 5th gear but no pinking involved. I cleaned up the plugs (NGK BP5RES) which helped a bit but there was still some hesitation on an engine which has always been immensely flexible and tractible. The plugs looked a bit worn so thought I'd treat myself to a new set and had a look over the net. I came across this.
http://www.ngkpartfinder.co.uk/cars_commercial.php
It recommends BP5E for carb'd Range Rovers & SD1's before they went to fuel injection which take BPR6E. Anyway, I found a set of these on the net for about a third of the price in Halfords (who were out of stock), gapped them and after fitting all was well again.
It could be down to the change to BP5E plugs or just fresh clean plugs anyway. It worked for me.
Posted: 24 May 2009 14:50
by Marko
the letter R in the spark plug code refers to resistor built in the plugs to reduce electrical noise ( ECU can suffer from this)
your improvement probably came from the set of "new plugs" and not the change of the model. spark plugs age even if they look fine. the insulating ceramics start to be porose , surface of the electrodes oxidizes,.... in short they age and dont work well as before ,
combined with old distributor cap, rotor arm, points the effect worsen.
