The idea of a 3 ton SUV rolling up my rear bumper is not a good thought. I noticed that the rear lights on my TR7 aren't nearly as bright as modern cars, so I thought I'd accomplish two things at once - add a rear spoiler and a third brake light.
Thanks to Mickey, I had a rear wing/spoiler that I wanted to mount and thanks to eBay, I bought a third brake light (LED) that fit the contours of the wing. I glued the light to the wing and with a dremel, cut a channel from it to a mounting post. I drilled a hole through the mounting post and met up with the channel.
A little JB weld held the wires down into the channel and the wires went smoothly into the post hole...
I bondo'd over the channel, sanded everything down, and painted the wing satin black...
(That's masking tape over the brake light)
I mounted the wing on the car - that was the scary part - drilling into the sheet metal (measure 8 times, drill once!)[:)]
Ran the wires through the trunk lid bracing and tied them together with the license plate light wires and out through the bottom. Tagged and soldered them into the brake light circuit and re-installed all removed covers, etc.
I removed the tail light assemblies and cleaned the bulbs, connections, and polished the tail light lenses with plastic polish to remove all the faint scratches and hazing. I painted the worn reflector areas with gloss white paint. I was going to use silver, but research online showed that white gives better results. Re-assembled, and here's what I accomplished...
Pictures don't really capture the brightness of these lights, but they are MUCH brighter than before and the wing brake light is closer to eye level of other drivers. If this keeps just ONE person from tagging my rear end, it will be well worth it.
Plus, now that I have the stabilization of a rear wing, I don't have to worry about the car losing traction in the rear at 150 mph...[;)]
Aaron
