Hi Debs
IF there is no power being fed to the starter solenoid as the recovery guy says then the relay as in Zoe case may be the problem, but a faulty solenoid can cause the relay to fail, so POSS both required. The relay sits in the fuse box on the side, can normaly be felt or heard to click when starter operated, if clicks this means the switch side of relay ok not nec the contacts inside which may be burnt.Caused by a faulty solenoid or high resistance somewhere in this side of the circuit.Starter held in by 3 bolts under the exhaust manifold, not the worse job in the world but can be messy, a lot of oil and crud finds its way down there.
May of cause just be a loose wire on the solenoid itself, looks like your other half may get his hands dirty!
