Rear Trailing Arms
mitchelltjohn
Rear Trailing Arms
Postby mitchelltjohn » 08 Jan 2009 22:14
one of my rear trailing arms split in two just ahead of rear bush last week. Result of slowly traversing a speed hump! Is this a common occurance? Has this happened to anyone before? Anyone any experience of make a claim?
standard 1981 DHC
Postby paul w » 09 Jan 2009 08:45
Never been unfortunate enough to claim against that,but the trailing
arms design traps water,and water promotes rust.Add road dirt and time,
and metal fatigue results.
You can improve the arm by welding a strip on the open top to stop
water/dirt laying in the channel.
Postby Wayne S » 09 Jan 2009 11:31
Easy and relatively cheap to replace as well. Get the supplier to push some poly bushes in for you and supply new bolts and your away. Changed both mine in an hour.
Postby Beans » 09 Jan 2009 17:37
Easy and relatively cheap to replace as well. ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Unless the bolt is rusted solid in the steel insert from the rubber bushes [B)]
Postby busheytrader » 09 Jan 2009 21:39
Was that one of those "separated" humps that can be straddled? My single pipe system and / or lower V8 radiator mount always grounds on these unless I drive one side of the car directly over them. The full width ones aren't so bad.
One of the London councils made the local TV news (might have been Islington) when it was found out that most of their speedbumps were above regulation height. A classic Mini Cooper owner was going to sue them after losing his second exhaust system to them. It might be worth measuring the speed bump height and checking the regulations. They might be on the web somewhere.
TR7 V8 DHC Jaguar Solent Blue. 9.35cr Range Rover V8, Holley 390cfm, JWR Dual Port, 214 Cam, Lumention, Tubular Manifolds, Single Pipe Exh, 3.08 Rear, 200lb Spax & Solid Bushes, Anti- Dive, Granada Vented Discs & Calipers, Green Stuff, 4 Speed Rear Cylinders, Uprated Master Cylinder & Servo, AllyCat 5 Spokes. No Door Stickers. Mine since July 1986, V8 from 1991
Users browsing this forum: No registered users and 92 guests
