Postby busheytrader » 06 Dec 2008 21:50
Phil,
I'd be very surprised if it's the air scoop unless you have any unsealed holes in the bulkhead underneath it. Rainwater runs out the bottom of the air scoop where it fits against the bulkhead.
If you had a DHC I'd immediately suspect the front corners of the hood. Since you don't, how about the seal at the bottom of the windscreen and the door cards? Blocked drain holes in the doors or ill fitted door cards help water run over the door seals.
TR7 V8 DHC Jaguar Solent Blue. 9.35cr Range Rover V8, Holley 390cfm, JWR Dual Port, 214 Cam, Lumention, Tubular Manifolds, Single Pipe Exh, 3.08 Rear, 200lb Spax & Solid Bushes, Anti- Dive, Granada Vented Discs & Calipers, Green Stuff, 4 Speed Rear Cylinders, Uprated Master Cylinder & Servo, AllyCat 5 Spokes. No Door Stickers. Mine since July 1986, V8 from 1991
