Serves me right, I guess.
Posted: 13 Oct 2008 10:59
for shooting my mouth off on Debs "just a service" thread about how
reliable my 7 is. The worst thing is, it's my own fault.
After a bit of running around, today, I stopped at the service
station to fill the tank. When I tried to start up, to leave,
nothing, absolutely nothing. Opening the bonnet, & looking at the
engine did not seem to help.
Fortunately the little lady starts easdily, & I only had to push her
a few yards, & jump in. She bump started easily, & i drove home.
There I put her up on the ramps, & checked the starter connections.
After cleaning & tightening them, nothing. Being an electrical
ignoramus I gave up.
So I called my friendly auto electrician. They have 2 mobile blokes,
& one was nearby, doing a tractor aircon service. An hour later he
was here, & showing me the error of my ways.
Someone had run a direct earth from the radio to up behind the dash.
They had somehow got this around the starter wire from the ignition
switch. I had inadvertently loosened this earth wire, when I was
under the dash, playing with the ventilation controls.
It had then got caught on the steering column, & wound around it,
pulling tight on the starter wire, which broke.
10 minutes later, after charging me the huge sum of $20, he was on
his way, but not before suggesting I should be more carefull of what
I'm doing with my left elbow, when upside down in the drivers
footwell.
Would you believe, my answer was not even rude?
Posted: 13 Oct 2008 11:53
by EntonoX
Not all problems have a difficult solution! [:D]
strange that it wound around the steering shaft. But a new wire is better than a new starter...
TR7, ACG 2700L
Posted: 13 Oct 2008 14:03
by HowardB
I sympathize with Hasbeen - we were about 5/8 way through the 48 hour Round Britain Reliability Run, when I filled up with 50l of ultimate diesel. Was totally gutted as the car has never broken down anywhere since I bought it last year, but still had to be recovered by the AA as there was nowhere at midnight on Saturday night in Mid Wales that could drain a tankful of diesel :(
After I got home I drained it completely (never realized that the tank was so large), refilled with clean petrol and after a few mins turning over, away it went. There are times when running an older car is so much less hassle than a modern fuel injected catalytic converter fitted repmobile.
Posted: 13 Oct 2008 15:39
by Wayne S
It doesn't look like many wedges (if any?) managed to finish the Round Britain Run unfortunately [V]
I was in a G TR4 Dove so wasn't flying the flag this time. I know TR Tony on here got as far as Pimperne though...
Didn't see any wedges in the car park at the plough after the finish.
Posted: 13 Oct 2008 16:19
by HowardB
According to Tim three failed (One master cylinder, one burnt out starter motor and one plonker who filled up with diesel), but I recall that the contact list showed 7 7's starting so four should have been there at the Plough. Roll on 2010.....
Posted: 13 Oct 2008 21:32
Well one (TR7-V8) was back at the Plough very early indeed [:D]
I als was in disguise again, in a mk3 GT6 [:I]
Posted: 13 Oct 2008 22:50
EntonoX, the wire caught on the clamp on the column, & was wound
around, with the column, as I turned the steering.
Posted: 14 Oct 2008 04:28
by cliff
<b>$20.00 for a house call</b>. Cheap at twice that. If you can get someone to make a house call in the US, the first thing they want is to tow it back the shop and put it on the analyzer at $60.00 a pop plus tow and parts. If you get if you get your car back for less than $200.00 you have been very fortunate. Keep the dirty side down and the shiny side up!!!
[:)]cliff
Posted: 14 Oct 2008 06:28
Cliff, that's what it would normally cost here, if he had to come
out from town, but he was at a neighbours turf farn, just across the
valley. Thats why I mentioned the "huge" sum he charged me.
As I did not require a receipt, I think that was for a round of
beers for the boys, after work. One advantage of small towns, where
everyone knows each other.
These blokes deal with a lot of big heavy farm machinery around
here, so they are set up to fix things on sight.
They fitted a couple of brake light globes, for my daughter the
other day, at the shop, for the cost of the globes, only. She is
pretty, with great legs, & short skirts, I wonder if that helped?
Posted: 14 Oct 2008 21:26
by Debpazvin
I'm really glad it all worked out for you in the end and you,in no way, "blame" me for putting some sort of in-built curse into my "just a service" thread which (by the way) is a continuing saga (should you wish to add anything else?) [:)]
Deb x
1980 Premium TR7-1 of 400 made.Image
Posted: 14 Oct 2008 23:05
Na Deb, Its the old one about pride & fall & such stuff.
