Wedge spit dimensions - CONFIRMED
Posted: 27 Jul 2008 11:15
Forgive the ascii art - the following confirms the dimensions for a wedge spit, something I said I would do some time ago.
Code: Select all
| TR7 FHC SPIT/ROTISSERIE
| CRITICAL DIMENSIONS
| END ELEVATION
| X --------
| | | 935 mm
| X X
| | 1200 mm min |
| | 1500 mm rec |
| SIDE ELEVATION
| ----- || || --x--
| ------x--||-------------------- 3825 mm min ---------------------||-------
| X X
| Nb 1. The vertical dimension of 935 mm provides minimum clearance for rotation
| of the FHC shell. The DHC may require less height but this has not been
| verified.
| Nb 2. Using the recommended base width of 1500 mm eliminates instability when
| rotating the shell.
